flexplate
Old May 4, 2007 | 07:57 PM
02fastbird's Avatar
Default flexplate
i bought a flexplate at carquest for my 02 t/a,to do a m6 to th400 swap,anyways the flexplate has a weight on it.i thought the ls1's where internally balanced .thanks for your help.
Old May 5, 2007 | 10:11 AM
john kilgore's Avatar
Default jw
jw in florida makes a crank adapter and that is all you need
Old May 5, 2007 | 10:24 AM
jay_lt4's Avatar
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
Old May 6, 2007 | 03:01 PM
02fastbird's Avatar
still didnt answer my ? about the weight...
Old May 6, 2007 | 06:10 PM
jay_lt4's Avatar
there is no weights on any of the 4.8,5.3,ls1,6.0's flex plates
they probly sold you a gen1 or gen2 flexplate you need a gen3 small block flexplate
Old May 6, 2007 | 11:23 PM
02fastbird's Avatar
i checked the fly wheel bolt pattern it fits an ls1..
Old May 7, 2007 | 07:58 AM
spy2520's Avatar
i dont remember any weights being on my new or old flexplates...
Old May 7, 2007 | 11:21 AM
jay_lt4's Avatar
doesnt matter if it bolts to your crank,, it isnt the correct flexplate, i have never seen a 4.8,5.3,ls1,6.0 with a weight on the flexplate
which flexplate you trying to run, the gen3 flat or curved, what crankshaft spacer/adapter are you going(gm or hughes) to use to keep the th400 converter
read my previous link, it is all in there
 Michael S. Palmer
