T-56 to TH-400
Old Jun 14, 2007 | 12:01 AM
XpEdItIoUs's Avatar
Originally Posted by Blown 98 Z
Spun a bearing at the track....the TH 400 works great, sucks I don't get to enjoy it.
New block and rotating assembly are at the machine shop this week, I should have the new motor in by the end of the month.
What was your first impression when you first took her for a ride with the new tranny?
Old Jun 14, 2007 | 06:14 PM
Blown 98 Z's Avatar
I was thinking another gear would be nice.
Old Jun 14, 2007 | 06:34 PM
XpEdItIoUs's Avatar
lol, what gears do you have at the rear?
Old Jun 15, 2007 | 08:45 AM
Blown 98 Z's Avatar
411 Pro Street gears.
Old Jun 15, 2007 | 11:31 AM
6techniques's Avatar
...I bet she screams down the street.
I got my th400 finally--which was free by the way (from my dad-in-law)! so it looks like Ill be building my own versus buying a pre-built one.
Old Jun 15, 2007 | 02:33 PM
XpEdItIoUs's Avatar
Wow, i have 3:50's with my turbo setup. What brand converter do you have and what stall speed?
Old Jun 15, 2007 | 09:27 PM
Blown 98 Z's Avatar
Vig 4000
Old Jun 15, 2007 | 09:58 PM
XpEdItIoUs's Avatar
Vig 4000
how do you like it?
Old Jun 16, 2007 | 08:24 AM
anarchy99's Avatar
I'd like to know how you like it also as I was thinking of using that one also on my m6 conversion.
Old Jun 16, 2007 | 10:55 AM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
i had a vig 4500 in my lt1 car. it is the same converter that i am putting in my ls1 car. just sent it back and had them change the pilot on the converter. i loved mine in the lt1
Old Jun 16, 2007 | 11:45 AM
Chris Gage's Avatar
My car felt great... I have 3.42's so cruising at 55 in 3rd wasn't so bad. The install was alot cleaner then I thought. I dont miss the t-56
Old Jun 16, 2007 | 05:34 PM
  #32
Blown 98 Z's Avatar
All things considered....I really like it.
I also run a pretty big cam for a stock cube motor, I thought that there would be some drive-ability issues with the cam and 4000 stall.
It's mild when you need it to be, and when you mash the pedal it runs like a raped ape.
Old Jun 16, 2007 | 06:17 PM
  #33
john kilgore's Avatar
Default gear
you guys that worry about gear ratios with a th400 why not just put more gear in the trans and put a smaller gear in the rear
Old Jun 16, 2007 | 06:39 PM
  #34
XpEdItIoUs's Avatar
its easier to chage axle gears that trans gears.
Old Jun 16, 2007 | 06:42 PM
  #35
Ryan'sSS's Avatar
I loved my TH400 at the track. I hated it on the freeway. So much so that I went back to a 6 speed. At the track, I only shaved .20 off my best time with a TH400 vs T56. I was just way more consistant.
Old Jun 16, 2007 | 06:46 PM
  #36
XpEdItIoUs's Avatar
Blown 98 Z, what converter bolts and flexplate bolts did you use?
Old Jun 16, 2007 | 07:28 PM
  #37
Blown 98 Z's Avatar
I used the flexplate bolts that came with it TCI.
The converter bolts that Precision Industries sent were too short....I don't remember exactly but I think they were M 10 x 20 MM long????
Old Jun 18, 2007 | 08:47 PM
  #38
BROOKSS's Avatar
What do you do about a speedo?
How did you mount yalls shifter?
Threw a stock auto console?
What about the hole in the floor board?
Old Jun 20, 2007 | 07:57 PM
  #39
Blown 98 Z's Avatar
Originally Posted by BROOKSS
yalls
Old Aug 30, 2008 | 12:50 PM
  #40
Blown 98 Z's Avatar
TTT
Good info.
