What stall converter would you run?
Old Oct 10, 2002 | 08:08 PM
Boosted One's Avatar
Default What stall converter would you run?
I have a ls1 with a TH400 behind it. It is in a 64 Chevy II that tips the scales at about 2800 lbs. The motor is basically stock right now but I plan on putting in a bigger lumpy stick and running a small shot of nitrous through it (125hp). What stall converter would you guys run if you were in my shoes?
Thanks
Frank
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Oct 11, 2002 | 06:41 AM
boomcase's Avatar
Default Re: What stall converter would you run?
With a turbo 400 with stock motor in a light car id try a tci super street fighter 3500 stall or a coan 3500 both descent converters for the money.
Old Oct 11, 2002 | 09:56 AM
Ragtop 99's Avatar
Yank YTP 4000 or TCS Pheonix 4000
Old Oct 11, 2002 | 03:57 PM
Wow, I didn't think I would need that much stall. Thanks for the help.
Frank
Old Oct 11, 2002 | 04:08 PM
P&DZs's Avatar
Here again the question of how do you intend to use the car comes in. Is your goal a bad a$$ 1/4 miler with rear tubb's and big gummies. If so, then the big TC's are going to get you there. If you are putting together a street cruiser that will shock the s--t out of a lot of rodders and still get 20+ MPG highway then a conservative TC like the 2400/2800 Vig' is going to be tough to get the traction to the pavement with the available rear wheel well room you're dealing with. What are you building towards ?
Old Oct 11, 2002 | 08:32 PM
Ragtop 99's Avatar
He's better off with more stall and less gear, even for the street. Less than a 3000 stall is a waste with an LS1. You drop too low rpm wise on the upshifts. A SY 3500 for street use is the minimum I would use unless you are more show than go. At your weight, a 3500 stall will not feel real loose, even with a low gear like 2.73s.
Old Oct 12, 2002 | 07:54 AM
My plan is for a bad *** street car that can drive to the track and lay down some impressive numbers. I'm more concerned with performance rather than gas mileage. Out back I have a Dana 60 with 3.73s. The car is mini tubbed to fit a 28x13.5 et street.
I talked to ATI and TCI yesterday and they both pretty much agreed they wouldn't do anything less than 3000. Both of them tried to sell me a 3000 stall converter with anti baloon plate. I'm not to sure if they're saying that cause it's what they have on the shelf or if it's really what I need.
Thanks for all the help guys!
Frank
Old Oct 12, 2002 | 02:24 PM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong>Yank YTP 4000 or TCS Pheonix 4000</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup.. any less stall and you'll be looking for more.
If you plan to add N20 to the mix then a small stall might be better.. but for kick azz NA times... go for at least a 4000.
