Possible 4.10 install problem ......
Old Oct 11, 2002 | 03:17 PM
Kevin V 2002 SS's Avatar
Default Possible 4.10 install problem ......
I'm planning on putting in 4.10's on my 2002 SS and I heard that there is a problem in putting in 4.10's on the 2001's and 2002's, something about a part rubbing, a paddle??? Sorry, I'm not up on all the details in the diff. I have the Torsen.
Has anyone installed 4.10's in their 2001 or 2002 F-Bod. Did you have any problems or know what the problem is???
<small>[ October 11, 2002, 03:18 PM: Message edited by: Kevin V 2002 SS ]</small>
Old Oct 11, 2002 | 03:23 PM
Magnus's Avatar
LS1TECH Sponsor
Default Re: Possible 4.10 install problem ......
Are you installing them yourself or having a reputable shop do it?
The problem is the thrust block.
To be general...
You take off the dif cover.
5/16" bolt comes out..
You pull the block that the bolt was holding in out of the center of the differential.
You push the axles in and remove the c-clips.
That block is the problem.
when you put the new 4.10 ring gear on, it extends just a pinch over the entrance hole for the block.. the block MUST go in straight.. can't be wiggled in..
What you have to do is grind it down a little bit.. I ground a groove on the bottom of one side and a groove in the top of the other side.. It gives it a little bit more of play to wiggle in.. and still does the job of keeping the axles out.
HTH
Old Oct 16, 2002 | 03:10 PM
I have a friend installing them, who is really good. Turns out he knows about the paddle problem, that a little grinding is necessary.
For those with the Zexel Torsen rearend, where id you get your install kit and what was the part number?????
Old Oct 17, 2002 | 02:05 PM
AZ28driver's Avatar
Look to the right. SLP has just the kit you need.
Old Oct 20, 2002 | 09:27 AM
wizkid's Avatar
Install Director
Found the same thing out when I tried installing a 02 torsen in my 99 Z with a 4.10.
Get the SLP paddle kit or do like I did, grind.
Eric
