adj master cylinder install
Old Oct 12, 2002 | 09:36 PM
PG's Avatar
PG
Default adj master cylinder install
Just wanted to ask how difficult it is to install the mcleod adj master and also how much adjustment is needed? I am gonna attempt it tomorrow, just needed an idea on how to adjust
Old Oct 12, 2002 | 10:07 PM
DERTY's Avatar
The Bull
Default Re: adj master cylinder install
It's actually not bad. I'm wondering if you have the old model that requires the u-bolt or the new model which has tapped holes in the master. If you have the old model I'd recommend drilling and tapping the holes a little larger. That makes the install a piece of cake. It's a blind install, so you basically have to slide it up and under the brake booster through the firewall. Adjustment is pretty easy as well.
It'll take you about an hour to figure it out the first time. I've got it down to a 20 minute job to take out or put in. Mostly removing the STB, kick panels and disconnecting it from the tranny.
