Stall or gears
Old May 19, 2007 | 08:14 PM
ELLIS's Avatar
Originally Posted by spy2520
i hit 1.72 with all-season tires.
What tires are you using? Do you have 2.73's with your stall?
Old May 19, 2007 | 08:22 PM
Strahley's Avatar
Stall first, gears or a new rear end later
Just make sure to match up your stall, choice of gears, and cam. For 1/4 mile ETs, this can make or break the car
Old May 19, 2007 | 09:29 PM
bene's Avatar
Trunion King
Save some more money and do both. I did.
Old May 20, 2007 | 05:17 AM
00slowredz's Avatar
what kinda mpg are u guys getting with 3000-3600 stalls???? i drive approx. 60 miles a day and i dont want a stall to make it any worse then it already is. this is why i want to do an m6 swap
Old May 20, 2007 | 02:23 PM
RevGTO's Avatar
Pontiacerator
If your driving is on the highway, it won't affect it, or maybe improve it a little since it's lighter. If you're in a lot of traffic or surface streets, the stall will cost you some. My stall is a 3000, and it cost me 1-2 mpg in town. Maybe +1 on the highway.
Old May 20, 2007 | 02:52 PM
sixvi6-camaro's Avatar
I drive my 3600 stall 40-50miles a day and love it. No change at all in mileage on the highway because once in lockup its the same as a stock stall. overall average with mixed traffic and highway was only a 1 mpg drop. That was when I had a stall and 2.73's.
Gears will cost you more of a MPG loss from highway driving than a stall will in traffic imo. I lost around 3 mpg form the change to 3.73's.
Old May 20, 2007 | 03:53 PM
Strahley's Avatar
My last trip to the race track, I averaged right at 22 MPG, and that was with cruising at 3k rpm on the highway/interstate (a3 instead of an a4 here), doing some city driving, and making 6 passes
Old May 20, 2007 | 04:13 PM
BlackHawk T/A's Avatar
There are other threads on this and a search would bring them up...but not to go off topic, I could see how it depends what you have now. 3.23 cars are obviously better off than the 2.73 cars where a gear swap would be more beneficial.
Old May 20, 2007 | 06:19 PM
RevGTO's Avatar
Pontiacerator
My 2.73/3.42 swap cost me nothing in town. Maybe 1-2 on the freeway but I didn't have the 2.73's long enough to ever do trip mpg with them.
Old May 20, 2007 | 06:54 PM
spy2520's Avatar
i got 3.23s, and i cut those times on 235/60/16 Goodyear LS.
Old May 22, 2007 | 09:04 PM
ELLIS's Avatar
Is the tune after a gear intall only to correct the speedo or is their other things that need to be adjusted also.
Old May 22, 2007 | 09:26 PM
  #32
Hell'sChariot's Avatar
I would say just the speedo.
Where in nebraska are you?
Old May 22, 2007 | 09:29 PM
  #33
Detoxx03's Avatar
Since I put my stall in I have fallen back in love with my car. It helps from a dig but is no slouch from a roll. Get the stall first and you will not be disappointed.
Old May 22, 2007 | 09:44 PM
  #34
Rowdy94's Avatar
You will need to tune for new shift points. They will be off, as in the computer they are a MPH value, rather than an RPM value.
At least that goes for LT1s, LS1s are likely to be the same.
Old May 22, 2007 | 10:25 PM
  #35
bene's Avatar
Trunion King
W/ 3.42 and yank 3500 2.5 str I get 240-260 miles/tank city driving w/ some highways and on highway I get almost 400 miles/tank IIRC.
Old May 23, 2007 | 07:35 AM
  #36
ELLIS's Avatar
Bellevue/Offutt AFB
Old May 23, 2007 | 08:35 AM
  #37
SOMe WS6's Avatar
no question.... STALL
Old May 23, 2007 | 05:24 PM
  #38
BobDoLe's Avatar
i would go with 3.73 gears (instead of a stall) if i had 2.73s. i realize that my opinion is going to be the minority, but allow me to explain and maybe someone will chime in with valid counter-points.
the overall feel of the gear change from your 2.73 to 3.73 would be dramatic. even if doesn't quite translate to anywhere near as much of a difference on the track, the sotp feel seems to be widely recognized as priceless around here.
the stall is really going to build up a lot of heat in your transmission and nobody likes a hot transmission. i'd also expect it to be a pain when it comes to keeping traction (especially on wet road surfaces).
i realize a stall is great because it brings the torque, but greatly adds to heat and traction problems - not an issue with drag radials at the track.
Old May 23, 2007 | 06:53 PM
  #39
ELLIS's Avatar
I think I see your point. A stall is more suitable for drag racing with slicks and gears are a better fit for a DD. It looks like most of the people who said "Stall first" already have 3.23's or higher and do alot of drag racing. The more I read these threads I realize I should probably do gears first since this is my DD have no plans on drag racing. I may go once just to see what the car can do but thats about it. Thanks for your input
Old May 24, 2007 | 12:31 AM
  #40
performabuilt's Avatar
LS1Tech Sponsor
Even though it does not help me sell anything I would honestly say gears then stall
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
