Ram 910 disk, 402 PP and Hayes Billet FW installed
So far so good. This clutch grabs initially a hair softer than my McLeod Revlok II clutch but once it grabs, it hold hard
Working fine with stock hydraulics too (I'm going to make an adj master from a stocker I have laying arouund). So far I like it
I can shift faster than you.
Brian, how is the pedal pressure compared to the Mcleod?
I have installed a few of these setups and they work well!
seems to be an identical PP as what was used with the revised Revlok clutch...feels like the same pedal pressure. Its not as abusive on takeoff but grabs hard when it does finally engage.
Jason...check your PMs
I think they are comparably priced. I just had a Hays flywheel in my possesion and didn't want to buy another FW.
Yep, that is what I thought too about the PP.
I have installed a ton of these Mcleods and a few RAMs and noticed the same thing.
I got the PM. Thanks for the heads-up. lol
Jason
I have installed a ton of these Mcleods and a few RAMs and noticed the same thing. I got the PM. Thanks for the heads-up. lol
Jason
