Yank A4 tranny x-member
Old Oct 16, 2002 | 09:02 AM
Joe99SS's Avatar
Default Yank A4 tranny x-member
Anyone else have one? I finally received mine on Monday and upon further inspection, the little c-shaped bracket that is used for the TA mount doesn't line up with any of the holes except for the bottom set... I thought it was supposed to be adjustable using the other holes? Also, what TA bushing is everyone using with this? A poly one? Any part numbers?
Thanks...
Old Oct 16, 2002 | 02:58 PM
Joe99SS's Avatar
Default Re: Yank A4 tranny x-member
Thanks John, mine didn't come bolted on... and the only holes that line up are the bottom set of the 4... I guess I'll have to call Yank and see what's up... <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Oct 17, 2002 | 12:22 AM
WILWAXU's Avatar
Hey Joe!
.. my x member is sitting on my kitchen table <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
The one I have has the holes in a straightline... the c came bolted in the middle setting.
You can get a poly TA mount from one of our sponsors, should be a stock replacement. That should be all you need.
I'm looking into a stock replacement style TA now...
Old Oct 17, 2002 | 12:45 AM
Ragtop 99's Avatar
Mine worked fine with my BMR arm.
