car wont go into park....
Old May 21, 2007 | 08:44 PM
orange1999ws6's Avatar
From: rochester ny/ cannon air force base, new mexico
Default car wont go into park....
its a 1997 trans am with an automatic transmission and it wont go into park... and i dont want my friend to buy it unless its somthin simple to fix....
when the car is off, ignition on the car only goes into neutral and drive but not reverse or park
when the car is on it will go through everything except park
and when the car is off completley with the key in and in acc. not on it wont go into reverse or park
ive checked for binding with the linkage and there is nothing in the way stoping it from going forward... my guess is the lock out mechacinism for park and reverse while the car is driving is stuck... some sort of way or somthing or the tranny is just screwed up
any ideas?!?! thanks !
Old May 21, 2007 | 10:14 PM
Predator T/A's Avatar
you proly have goo on it from spilling sodas from the sorry *** cup holder
Old May 22, 2007 | 02:07 AM
revtime's Avatar
Not sure if this could be it or not but have you checked the "step on brake to shift from park" cable?
Also try rolling the car forward or back while in neutral.
