Harlan 2-Step
Old May 24, 2007 | 07:09 PM
XCLR8N's Avatar
Default Harlan 2-Step
So as you guessed I have a Harlan 2-step. I am wondering is there is a place I go to look at a wiring diagram for these or if you all can give me advice in wiring this device. I have the unit in the car for the most part with exception of the ground on the momentary switch and where the yellow and gray wires in the engine bay are connected. Any advice would be greatly appreciated
Old May 25, 2007 | 07:46 AM
XCLR8N's Avatar
So am I the only automatic LS1 guy that has a two-step?
Old May 26, 2007 | 11:58 AM
nutz'00 Z28's Avatar
https://ls1tech.com/forums/attachmen...chmentid=94622
Here is a drawing of how mine is wired, the yellow wire is used to deactivate a nitrous system or to wire to a active indication light.
