trans cooler
Old May 28, 2007 | 11:35 AM
ls1motorsports's Avatar
Default trans cooler
is there any particular trans cooler i should get? i was looking at one from summit racing http://store.summitracing.com/partde...5&autoview=sku or will any trans cooler just do?
Old May 28, 2007 | 12:09 PM
Tainted's Avatar
the bigger the better
Old May 28, 2007 | 07:56 PM
smoknta's Avatar
I second that.
Old May 28, 2007 | 08:02 PM
performabuilt's Avatar
LS1Tech Sponsor
The largest cooler you can fit practically is what you want.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 28, 2007 | 11:02 PM
Matt D's Avatar
Retired Street Racer
I use the B&M cooler 70266. It is a 28,000 GVW and works great.
Old May 28, 2007 | 11:10 PM
spec_j's Avatar
i third that, which makes it a law in 9 states lol.
but the one im going to go with its like a 38,000. Should be enough for my stall and built trans. Just ge the biggest possible one that will fit on the car. Doesnt matter if its the ugliest thing on the market, if its big is good.
Old May 30, 2007 | 10:41 PM
now what is a 28000 and a 38000 what do thoes numbers stand for? and would you happen to know the dimessions on the b&m 70266.. i was looking at this one from summit . its earls performance. 5 in. x 13 in. x 2 in.. is that an ok dimession?
Old May 30, 2007 | 10:59 PM
or i should ask what is the most popular dimesion or trans cooler people go with that works efficently
Old May 31, 2007 | 01:15 AM
bmxer8699's Avatar
but what about in the winter? wont a large *** cooler take for ******* ever to get the tranny to get warm?
Old May 31, 2007 | 01:36 AM
smoknta's Avatar
The numbers are GVW, which stands for gross vehicle weight. The larger ones are actually made for motor homes. But they work perfectly for high stalled cars. I would seriously get the biggest you can find. Just make sure that it will fit where you want to put it. I put a 28K gvw in my car.
Old May 31, 2007 | 11:16 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Get a Perma Cool with a 900 cfm fan. That will do the trick.
Old May 31, 2007 | 11:21 AM
LS1Tech Sponsor
The cooler temps and longer warm up time will not hurt anything , The PCM monitors fuild temperature and modifes the presure and shift quaility accordingly.As far as the added warm up time from the PCM perspective your drivng in alaska lol and its just takes a bit longer to get warm , It dosent know the difference.
__________________
Call 888-744-6542
Old Jun 2, 2007 | 01:42 AM
where do you guys typically mount your trans cooler?
Old Jun 2, 2007 | 09:10 AM
LS1Tech Sponsor
We mount ours in front of the air conditioner condensor.
__________________
Call 888-744-6542
Old Jun 2, 2007 | 10:07 AM
Bryan @ Speed Inc.'s Avatar
i have no front grill, bumper support, or A/C... i'm mounting mine right in front of the passenger side hole in the bumper cover - straight shot for plenty of air to move through it.
Old Jun 2, 2007 | 02:04 PM
SCREAMIN's Avatar
mount it anywhere there is room on the radiator
Old Jun 4, 2007 | 08:00 AM
Where exactly? Or do you mean a/c condensor?
Old Jun 4, 2007 | 08:45 AM
Matt D's Avatar
The B&M 70266 is 11x8x1.5"
Most of the hardcore drag racers like me remove the A/C and put the trans cooler right where the condensor used to be. It fits perfectly in there and gets plenty of air to it.
Old Jun 4, 2007 | 10:07 AM
LS1rulz's Avatar
Do you guys run through the stock cooler first? Simply physics says it's best to go:
Tranny -> stock cooler -> aftermarket cooler -> tranny
But there's always some wannabe genius who doesn't understand the air/water, air/air efficiencies, and says to avoid the stock cooler. But that makes no sense. When sitting still in traffic, I want the air/water cooler's help for sure.
Old Jun 4, 2007 | 10:16 AM
yea - the instructions tell you to use the factory cooler in series with the B&M unit. i installed mine yesterday - it was very easy.
i used a couple self tapping screws into the lip of the radiator support. it's pretty sturdy there, and gets plenty of air through the front bumper cover.
