Trans-Go + 2001 "Z" = -10deg timing after shift??
Old May 1, 2003 | 06:46 PM
F1's Avatar
F1
Default Trans-Go + 2001 "Z" = -10deg timing after shift??
Man It shift so freeking hard but the timimg goes way down, the car bogs and studders untill I let out of it.. It only does it on the 1-2 shift 2-3 is fine. Please tell me this is the dreaded TM problem.. I did the same thing to a 2000 SS and it has no problems.. Is it more typical on '01's?? The car also has the stock converter..
Old May 1, 2003 | 10:22 PM
gator's 99TA's Avatar
Default Re: Trans-Go + 2001 "Z" = -10deg timing after shift??
TQ management is sounds like, esp considering it is a 01 car.
Old May 2, 2003 | 07:26 AM
jimmyblue's Avatar
Moderator
Maybe not torque management but rather misfire
detection and gross timing pull. I think TM is
a before-the-fact deal (pull timing before &
during shift). But, misfire detection is done
by watching the crankshaft sensor and if crank
speed changes "abruptly" then it will roll back
timing, unlock the converter, etc. A super-hard
shift apply might well meet the criteria if the
converter passes the torque bump effectively.
I gather that the answer to this is to increase
misfire count needed for converter unlock and
whatever other misfire-driven self-protection
functions might be there.
