late trans shift
Old Jun 7, 2007 | 12:00 AM
Tiger2o69's Avatar
Default late trans shift
Search wont work so ill just ask..
I have my trans to shift at 4800 and its still shifting at 6300.. I want the trans to shift at 6000 for the turbo..
Car is probably making about 550hp..
Trans is build and I have a vig 3600..
Is there any way to know if its the trans or the torque converter? I know the 3-4 packs are good.. they were just put in..
Old Jun 7, 2007 | 12:06 AM
performabuilt's Avatar
LS1Tech Sponsor
are you lowering the MPH tables to match ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 7, 2007 | 04:14 PM
Tiger2o69's Avatar
yes.. mph is at 70 im shifting at 80..
I just had the trans checked out and the 3-4 clutches were worn a bit but not a lot..
Starting to wonder about the converter but it cost 250 to check it out...
Is there not a way to determine which is the problem? I have a data logger if that helps?
Old Jun 7, 2007 | 04:24 PM
LS1Tech Sponsor
Well watch to see if the PCM is comanding the shift in the data first
__________________
Call 888-744-6542
