Trans slipping and surging?
Old Jun 11, 2007 | 12:53 AM
Bowtieman4life's Avatar
Default Trans slipping and surging?
I recently bought a 2000 trans am w/ a failing trans. It surges from 3 to 4 on the freeway and it won't shift into 3 at wot. I have to let off the gas for it to shift into 3rd. The TCI 3000 stall still seems to work fine. 1. Is it time for a rebuild? 2. Can I re-use my TCI converter? 3. Any good tran shops in the Austin, Tx area.
Any help is appreciated.
Old Jun 11, 2007 | 11:31 AM
Predator T/A's Avatar
1. sounds like it
2. depending on how much sediment and parts are in the pan...to be safe i would at least have it opened and cleaned
3. contact performabuilt
does it slip any when it is in thr gears? outside a tuning or electrcal problem sound like its on it crutches
Old Jun 11, 2007 | 11:39 AM
performabuilt's Avatar
LS1Tech Sponsor
Yes I would think its dying . on the converter I would at least have it freshened up , Surging could be a sign of a bad converter clutch
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
