matching cam with converter
specs: 98-02 Comp Cams Xtreme RPM High Lift Hydraulic Roller Cam, 228/230 duration with .571/.573 lift and 112 LS. High RPM Street/Strip cam for use with LS6 or aftermarket intake. Requires computer modifications. 2000-6800 RPM operating range.
will this cam match up good with the stall? my friend who is selling it to me told me he started making power very high, wouldnt i want a cam to make power at around 4k rpms? can someone explain the importance of matching a cam with a converter?
Get a 3:72 or 4:10 gear set and then you'll be able to realize the full potential of your cam / converter package.
g
