Torque converter install?
Old Jun 15, 2007 | 12:02 AM
burnrubr88's Avatar
Default Torque converter install?
search isn't working right now so i couldn't find anything.
is there any good write up's on here explaining how to install a torque converter? any with pictures of the install?
Old Jun 15, 2007 | 08:01 AM
GregWS6&z28's Avatar
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old Jun 15, 2007 | 08:57 AM
Gilbert@Ace Racing's Avatar
When a converter is properly installed onto the pump, you should not be able to slide your fingers behind it. No part of the converter hub will be visible as viewed from the bottom. Be careful to get it right before installing the transmission as you could easily damage the pump and that would ruin your day. Take your time and you'll get it right the 1st time!
Good luck.
g
Old Jun 15, 2007 | 03:52 PM
CBR Crazy's Avatar
The magazine GM High Tech Preformance has a good wright up on how to do a TC change. It is on an LT1 but it should be pretty much the same thing on the LSx.
