important stall ?
Old Jun 14, 2007 | 09:56 PM
TravisMcGill2000's Avatar
Default important stall ?
hey guys i got a 94 TA i just put a 2400 b&m hole shoot stall in and it only stall 1500 rpm before it starts spinning the tires. wats the deal i thought it would at least 2300. any ideas please i have no idea.
Old Jun 14, 2007 | 10:14 PM
any ideas anyone .
Old Jun 14, 2007 | 10:17 PM
performabuilt's Avatar
LS1Tech Sponsor
Brake stall and rated stall are very different things, Only being able to brake stall to that RPM depending on your brakes etc may be normal. Nail the car suddenly in a quick snap while holding the brake and the E brake applied and see what the RPM jump to
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 14, 2007 | 10:19 PM
will i see any gains with a b&m 2400 on the track
Old Jun 14, 2007 | 10:22 PM
LS1Tech Sponsor
A little really though I consider much below a 3000 stall a waste of time. There are stock converters that go near 2400 stall ,
__________________
Call 888-744-6542
Old Jun 14, 2007 | 11:02 PM
another question is that when my car leaves hit sound like something hitting right under my seat any ideas
Old Jun 14, 2007 | 11:15 PM
LS1Tech Sponsor
sounds like the torque bar
__________________
Call 888-744-6542
Old Jun 15, 2007 | 07:44 AM
is it supposed to do that
Old Jun 15, 2007 | 08:36 AM
LS1Tech Sponsor
No you probably have a bad bushing or its come loose
__________________
Call 888-744-6542
Old Jun 15, 2007 | 08:54 AM
Gilbert@Ace Racing's Avatar
Be sure to check for proper alignment of the exhaust, check to make sure all of the fasteners are properly tightened... torque arm, rear trans mount, bell housing bolts etc...
I would doubt that you will see much of a MPH / E.T. gain with a 2400 stall converter. That is about the same RPM as a "maxed out" stock converter will produce. We have not seen favorable results using that low of a stall.
One thing you can try though is to not brake torque it when leaving the line... just take it off idle in order to put preload into the drivetrain. In other words flash the converter off the line. I know of several guys using that tactic at the track with good results, low and high stall converters.
Hope that helps.
g
Old Jun 15, 2007 | 04:29 PM
thinks guys
