transgo 4L60e-HD2 kit
Old Jun 16, 2007 | 09:24 PM
Tainted's Avatar
Originally Posted by performabuilt
Thats good too. Tainter had just ask me how I would set it up and how I do and I told him , Didnt actually plan on it being used in the forum publically allthough thats fine.
I figured what you had said would be great for everyone as a whole in most cases. if you like I can take that part out. I save all kinds of stuff like that you (as in the more educated and knowing folks) tell me and use it to help others.
I think we had said I was looking for soft shifts around town but a ncie ahrd hit at WOT where a 3k stall wont be slipping. if thats what I want, woild you do the 1/4 turn still or no?
Old Jun 16, 2007 | 10:19 PM
performabuilt's Avatar
LS1Tech Sponsor
Thats fine I dont mind just didnt want to get into a debate lol. But yes do it like i said and you will be happy with the results
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 16, 2007 | 10:22 PM
Tainted's Avatar
thank you once more performabuilt, my reccomendations and $$ goes to you!
Old Jun 16, 2007 | 10:23 PM
LS1Tech Sponsor
Your welcome as always
__________________
Call 888-744-6542
Old Jun 17, 2007 | 09:18 PM
AMS 72's Avatar
do you have too tear the trans completely down for this kit.
can you manually shift after install of this kit. and does the trans shift when you actually shift it.... like a manual valvebody set up.
Old Jun 17, 2007 | 09:33 PM
LS1Tech Sponsor
To install the entire kit you would have to tear the unit completly down however you can install the majority of it simply by removing the pan and valve body. The kit will allow you to hold down gears as long as you like however upshits are still PCM controlled, In other words if you shift from 1-2 manually at 2000 RPM at WOT the trans will still not upshift to second untill the programed RPM ussually something above 5000 rpm
__________________
Call 888-744-6542
Old Jun 18, 2007 | 07:44 AM
AMS 72's Avatar
Thanks for the info, the reason i was asking is this piece of *^%$ trans i have is bouncing off the rev limiter on th 2-3 shift on spray. would it be beneficial just to up the shif point, it does fine on the motor.
Old Jun 18, 2007 | 07:55 AM
troopercar's Avatar
performabuilt and FLT should put supercharged bigblocks on each of their trannies and bolt the tailshafts together and see who survives!
Decisions, decisions! I need one and can't make up my mind.
Old Jun 18, 2007 | 08:08 AM
LS1Tech Sponsor
Well if this helps any you get a 22000 gvw cooler with ours and a 1 year warranty and you get to keep your core oh and we can ship in 1-2 business days of your order and shipping is included in the price
__________________
Call 888-744-6542
Old Jun 18, 2007 | 10:49 AM
troopercar's Avatar
hmmmm performabuilt 1, flt 0
Old Jun 18, 2007 | 11:42 AM
LS1Tech Sponsor
thanks and of course we are allways right here when you need us
__________________
Call 888-744-6542
