Stall talk YANK vs. Viglante
When your converter stalls above your torque peak, you often lose valuable torque multiplication and efficiency. Basically, the motor is driving through the converter. Yank is a small company, but they are very very good at custom tailoring converters for your specific application. Stall speed is just one of the parameters. Shift extension, stall torque ratio and converter clutch engagement are also very important features you'll want to take full benefit of.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Your large motor with a big shot of nitrous is probably a good candidate for a larger 258mm converter. This would have more holding capacity when running on the juice. Something to consider.
I currently have a PT-4400 and I am cutting crappy 60's in the high 1.5s or worse lately.
I used to have some defective ARE S2 heads and a 226/234-.554/.575-112 cam. I was making peak TQ right around 4400rpm but it was hard to tell if I could have had more down lower because of the damned high stall on the converter.Now on this combo I would say that I might have been better off with a 4000 stall or so right?
Right now I am doing a combo with GTP S2+ heads (319cfm inatke, 220exhaust @.575) and the Piglet cam 223/.591/112. This setup is supposed to make power pretty high up in the rpm range, peak power being in the 6400rpm area? Will I need to change converters, or should I say, after I dyno, how will I know if I needed a smaller converter if I can't acurately read anything below 4400rpm because thats where my stall flashes to?
I am thinking of having my TC redone to a PT-4000 since that would help out on nitrous too.
Did I confuse the hell out of ya?
<small>[ October 31, 2002, 11:05 AM: Message edited by: F8LPONY ]</small>
I would keep the converter a PT4400 if you want the best 60' times, but if you plan on running the jug, a reduction in stall to a PT4000 will help you out.
<strong> how will I know if I needed a smaller converter if I can't acurately read anything below 4400rpm because thats where my stall flashes to?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">How about pulling with it locked up?
You could send your Vig back to Precision and have it restalled. I recommend a #6 impeller (like the Vig3200). That would make the converter more driveable and more efficient on the big end.
Kevin
