th350 or 400 conversion
Old Oct 22, 2002 | 10:27 PM
mobius's Avatar
Default th350 or 400 conversion
I have an A4 now and am considering the swap. could you please tell me everthiny that is needed. I have access to both a 350 and 400 that I can have built with a manual valvebody and all the stuff to make it stronger. My main concern right now is all the extras needed.
different driveshaft or modified? if so how?
crossmember, i see bmr makes one can i modify the existing? any instructions on that?
what about a torque converter? do i get one that fits a th400 or is something special required? what about the flexplate?
also what about the dipstick?
is there anything i am leaving out????
thanks!!!
Old Oct 23, 2002 | 06:33 AM
MacGyver's Avatar
Default Re: th350 or 400 conversion
I did the swap. Where in Orlando are you. Maybe we can meet up so you can check the car out. I swapped from an M6 but the only real difference is that you'll need some PCM programming to delete the A4 stuff from the PCM.
Will
Old Oct 23, 2002 | 06:47 AM
MADMAN's Avatar
LS1Tech Sponsor
I have the dipsticks in stock for either trans. Give me a hollar and I can give you some advice or sell you the whole kit. 281-449-8833
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 23, 2002 | 07:16 AM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
The TH350 can be made as tough as the TH400, but for more $$$. The TH400 is heavier, so that is a decision for you to make, weight or reliability.
The A4 crossmember can be modified very easily.
Get the dipstick from Madman
You will need a standard TH400/350 convertor.
The flexplate can be done several ways. My convertor was built to fit the stock flexplate.
You will need a different driveshaft, and tranny yoke.
If you go with a standard shift pattern tranny, you can use your stock shifter.
You can use your stock cooler lines.
You don't HAVE to get the codes deleted from the PCM, but you WILL have a constant SES light if not.
Tim
Old Oct 23, 2002 | 07:23 AM
LS1x2's Avatar
Formerly 4mulaJoe
Actually you will probably still have the SES light even if you turn off all of the DTC's related to your 4l60E. LS1 EDit does not fix this. It advertises that it does, but it does not. Carputing Inc. has no idea why and has showed no concern about it or plans to fix it. Just a heads up.
Old Oct 23, 2002 | 07:47 AM
sleeper6.0L's Avatar
go with the 400 it will last longer
Old Oct 23, 2002 | 01:05 PM
mobius's Avatar
Thank you for the info I am leaning towards the 400 as it is cheaper and cost is a big concern. I believe I know of a place that will build a converter to my specs suchas the ls1 bolt pattern. I have a ST 3500 right now the car is a daily driver with 3.23 gears I am running 315 nittos as well and love the way the car launches on the street, does the 400 have roughly the same ratio in first as the a4?. I was considering a 3000-3500 stall again I plan on running 100-150 shot of nitrous.
does the th-400 just bolt up in place of the a4?and just to go over it again i need the following:
dipstick
new driveshaft or modify existing
th400
th400 style converter
drill holes in flexplate or get moddeed converter
modify my crossmember
a new shifter
MacGyver I would like to meet up and check out your set up. send me an e-mail.
Old Oct 23, 2002 | 01:47 PM
LS1x2's Avatar
Formerly 4mulaJoe
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tim98TA:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 4mulaJoe:
<strong>Actually you will probably still have the SES light even if you turn off all of the DTC's related to your 4l60E. LS1 EDit does not fix this. It advertises that it does, but it does not. Carputing Inc. has no idea why and has showed no concern about it or plans to fix it. Just a heads up.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" /> Call Thunder Racing and ask them. They did my tuning and I have -0- SES lights with my TH400.
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It's not bullshit you moron. I could fix it with a shop(unlimited VIN version of LS1 edit too). All I would have to do is flash it with a m6 program and go from there. I don't have that option with my single VIN LS1 edit. My point is that I turn off a specific DTC, and the DTC still shows up!! Carputing has acknowledged the problem. They just didn't do a damn thing about it.
<small>[ October 23, 2002, 01:48 PM: Message edited by: 4mulaJoe ]</small>
Old Oct 23, 2002 | 02:07 PM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mobius:
<strong>Thank you for the info I am leaning towards the 400 as it is cheaper and cost is a big concern. I believe I know of a place that will build a converter to my specs suchas the ls1 bolt pattern. I have a ST 3500 right now the car is a daily driver with 3.23 gears I am running 315 nittos as well and love the way the car launches on the street, does the 400 have roughly the same ratio in first as the a4?. I was considering a 3000-3500 stall again I plan on running 100-150 shot of nitrous.
dipstick
th400
a new shifter
MacGyver I would like to meet up and check out your set up. send me an e-mail.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the first gear in a 400 is 2.48. you can upgrade to a 2.75, but its about $450. i dont know if you can get the 3.05 ratio thats in the a4 now. you can bolt the 400 right to the block, but you dont use one hole. so it mounts with 5 bolts instead of 6. or you can get an adapter plate that will allow you to use all 6 holes, but then i think you need a spacer for the convertor hub to slide into the flexplate.
Old Oct 23, 2002 | 03:35 PM
MacGyver's Avatar
Rob is correct with the 1st gear ratio in the TH400. you will lose a little going to it. I have a 2.75 first gear in mine and it was like 480 bucks extra for it. you CAN get a 3.0x first gear for it but I hear they are really weak parts and break often. Email is on the way mobius.
Will
Old Oct 23, 2002 | 07:54 PM
Tim98TA's Avatar
<strong>It's not bullshit you moron. I could fix it with a shop(unlimited VIN version of LS1 edit too). All I would have to do is flash it with a m6 program and go from there. I don't have that option with my single VIN LS1 edit. My point is that I turn off a specific DTC, and the DTC still shows up!! Carputing has acknowledged the problem. They just didn't do a damn thing about it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well how come my computer has NOT been reflashed to an M6, and Thunder simply deleted the codes and I have NO SES lights??????? Explain it!!!!!!
Tim
Old Oct 23, 2002 | 08:00 PM
The Derek H's Avatar
You can't flash an m6 file onto a PCM with the tuner version of LS1-Edit. It requires a Tech II to do so. Thunder has looked into one and doesn't have it so your claim is wrong. I have my VIN locked version of LS1-Edit and a th400 and I don't have many miles on the setup but no SES yet.
Old Oct 24, 2002 | 12:01 AM
Tim98TA's Avatar
Tim
Old Oct 24, 2002 | 07:11 AM
LS1x2's Avatar
Formerly 4mulaJoe
Tim</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I don't work for Carputing Inc. I am not the programmer who wrote or supports the software. How the hell am I suppose to know why it does not work? Simply put, I have turned off 8 DTC codes. 2 of them still show up all the time. Carputing's response is "I have no idea" when asked why their software does not work as advertised.
Old Oct 24, 2002 | 11:46 AM
Tim98TA's Avatar
<strong>Simply put, I have turned off 8 DTC codes. 2 of them still show up all the time. Carputing's response is "I have no idea" when asked why their software does not work as advertised.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Seems it's isolated to your PCM.
Derek, you actually DROVE your car????????? I better keep an eye in the classifieds, when it becomes for sale tomorrow. LOL
Tim
Old Oct 24, 2002 | 09:05 PM
Yeah Tim my car moves <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I twisted a puny aluminum driveshaft playing with my transbrake. Now all I need to do is get a new one made. My Spohn driveshaft I ordered was too short and they won't call me back afer I've left several messages. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> Imagine that huh. I don't need any measurements I do them all the time. But thats another story <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Oct 24, 2002 | 09:09 PM
GeorgeC's Avatar
4mulaJoe, what DTC's are still present?
Old Oct 24, 2002 | 10:18 PM
LS1x2's Avatar
Formerly 4mulaJoe
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>4mulaJoe, what DTC's are still present?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">P01860 AND P1810
They are definately turned off. Ken at Carputing has seen it, but offers no solution.
Old Oct 24, 2002 | 11:09 PM
mobius's Avatar
thnaks for all the replies... is there an after market flexplate available by chance>? is this an easy conversion? what is the easiest way to modify/buy a driveshaft for it
thanks
Old Oct 25, 2002 | 12:32 AM
LS1x2's Avatar
Formerly 4mulaJoe
Tim[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nothin special about my PCM.
