problems with TH400...
Old Jun 26, 2007 | 03:27 AM
RedsrtAk's Avatar
Default problems with TH400...
As you guys see from the title, I have a TH400 Tranny with a TransGo stage 2 shift kit
. It only does it at WOT say i'm normal driving(not that I do this regularly when d'ding the car)it will shift from 1-2-3 perfectly...my 1-2 shifts are fine...but when shifting from 2-3 it almost seems as if it completly misses third and my rev's will just climb....running off EFIlive software....my shiftlight is set at 6200 and the rev limiter is set at 6800...any input would be appreciated.
thanks,
david
Old Jun 26, 2007 | 08:09 AM
KRAZY K 2000 TA's Avatar
mine did the same thing and it was the pump,but that was just my trans so i am no trans guy.
Old Jun 26, 2007 | 08:21 AM
big wally 55's Avatar
Does it upshift imediatley if you lift off the throttle ? do tou have the detent solenoid hooked up ?
Old Jun 26, 2007 | 08:39 AM
WE TODD DID's Avatar
Sounds like high gear is gone.
Old Jun 26, 2007 | 10:08 AM
john kilgore's Avatar
Default slip
try running 12 volts through a switch to the male plug just rear of the shifter. the trans does not know you are at full throttle until it gets 12 volts at the passing gear switch. turn it on and punch it again with the trans in drive and see what happens. good luck
Old Jun 27, 2007 | 12:26 AM
RedsrtAk's Avatar
Detent solenoid is hooked up...upshifts fine...like I said its only at WOT....sooooo unfortuantly I am thinking the worst right now...but I hope it is the pump/less extreme scenario
Old Jun 27, 2007 | 07:54 AM
The reason I asked if the detent soleniod was connected is that it's job is to exhaust governor oil . This causes downshifts !!!Dissconnect the wire and try it . In regard to your pump , it will not cause one gear to work good and not another . It sounds like you are going to find a problem with the direct clutch !!!!!!!
Old Jun 27, 2007 | 10:36 AM
Gilbert@Ace Racing's Avatar
Direct clutch = High gear.
