daily driving question
Old Jun 28, 2007 | 11:14 AM
ChevyRyda99LS1's Avatar
Default daily driving question
I have a automatic 99z28, a guy that owns a transmission shop told me that I should use just my regular drive when I am in the city just driving around and use my OD only on long trips it will help me save alot of gas is this true. I noticed the regular D give me a little better take off.
Old Jun 28, 2007 | 11:17 AM
performabuilt's Avatar
LS1Tech Sponsor
OD on the highway will give better fuel economey but I dont think there would be any difference or improvement in economy around town in D. I tell people just leave it iN OD
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 28, 2007 | 11:47 AM
Gilbert@Ace Racing's Avatar
If it has a stock tune, the PCM will allow the converter clutch to lock up in third gear, that definately helps fuel economy and may account for the recommendation from your local shop.
But, anytime you can get it into overdrive the fuel mileage will be that much better. There aren't too many reasons I would recommend a customer to not use overdrive for city driving.
g
Old Jun 28, 2007 | 11:57 AM
ddcook07's Avatar
What about street racing? Would it be better to use the regular drive than the OD?
Old Jun 28, 2007 | 12:16 PM
LS1Tech Sponsor
You here from both sides of the isle on this one but the overun clutch is on in the D position and not the OD position and can help support the input sprag.
__________________
Call 888-744-6542
Old Jun 28, 2007 | 01:38 PM
Predator T/A's Avatar
i use regualar drive for city driving just not to lug the tranny and motor seems to keep it a tad bit cooler also on my temp guage also keeps the tranny from having to upshift and downshift so much
Old Jun 28, 2007 | 01:54 PM
TXZ28LS1's Avatar
i just keep mines in " OD" and i just let the tranny do the work. i dont manually shift or anything. plus i think im getting good gas mileage is cuz of the sporty 2.73's i have..
Old Jun 28, 2007 | 02:42 PM
5_02ls1's Avatar
what your friend is reffering to is gear ratio....if you have stock 273 gears drive is way better in town...mine had 273s stock...around here od was useless....i actually get better city mpg with 3.73s...i can use od now....as for racing I use D...
Old Jun 28, 2007 | 03:03 PM
ddcook07's Avatar
Just wonderin', didn't want to blow the tranny again.
Old Jun 28, 2007 | 03:13 PM
LMz28's Avatar
in the owners manual, i believe it says to keep the car in OD unless youre driving in the hills or traffic is really crowded...something like that. i keep mine in OD all the time. only time i put it into D is when i go through the mountains to go fishing or during really bad rush hour traffic.
Old Jun 29, 2007 | 09:20 AM
ddcook07's Avatar
Would it be bad to shift from D to OD during a street race?
Old Jun 29, 2007 | 09:33 AM
Dang man, street racing? Arent' there laws against that?
And then needing OD... on the street?
What gears do you have that predicate the need for OD on the street... must be 1/4 mile.
Old Jun 29, 2007 | 09:58 AM
mattraypharbor's Avatar
g
i have a custom tune with a 3rd gear lock up with a 3800stall but i drive it in od anyway 4.10's own me.
Old Jun 29, 2007 | 10:53 AM
I have posted here several times recently that we ordinarilly delete L/U in 3rd gear. There are several combination specific conditions that go into that determination... it is very vehicle specific. My experience has been tempered with many, many different cars and lot's and lot's of seat time with the guys next door at Xtreme Horsepower. We have worked together for a very long time putting together tuning mods that provide excellent driveability when compared to stock tunes after significant engine and drivetrain mods have been implemented.
Having 3rd gear L/U is not entirely a bad thing at all!
The key to remember about TCC L/U is it was originally designed to contribute to fuel mileage. In many of todays high powered DD combinations it is actually a detriment to driveability. Custom transmission tuning is required in many, many cases where the engine horsepower output, gears and torque converter have been upgraded from stock. Again, it is very vehicle / combination specific.
g
Old Jun 29, 2007 | 10:57 AM
g
thanks for the info Clears things up a bit..
By Brett Foote | 2026-06-04 05:00:17
