Do Not Put Tc On Flexplate First!!!!
Old Jun 28, 2007 | 01:33 PM
fgcox1's Avatar
Exclamation Do Not Put Tc On Flexplate First!!!!
Learn from my mistakes. Follow the correct procedures when reinstalling a trans. They are listed several times on this forum. READ THEM!
Important I could not get the pump out without removing the bellhousing
1. The bellhousing to trans bolts are TORX TP50's. THe TP stands for Torx Plus. Do not use a T50. It will strip out the torx head. Snapon has one but is extremely high ($25-35 depending on salesman). Search the "net, there are several available for under $10. I do not know their quality. One part number I found is OTC6191, SK has one, and there are several others.
2. Use heat as described in other threads. Even with the right socket and an impact wrench I still had to cur the heads off with a circular cutter.
Live and learn!
I have pictures of the damage to the pump but can't get them to upload. Let me know and I will send them.
Old Jun 28, 2007 | 01:36 PM
Predator T/A's Avatar
yeah not a good idea not likea manual trans lol where you put the clutch on first
Old Jun 28, 2007 | 02:05 PM
performabuilt's Avatar
LS1Tech Sponsor
Sorry you had a hard learn there. It happens more than you may know. We include complete instalation instuctions with ours and it still happens. But again sorry for your missfortune
Live and learn!
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 28, 2007 | 02:33 PM
5_02ls1's Avatar
Yeah my dad tried to tell me thats the way you done it when I was like 14 or so.....one of the very few times I called him stupid....Who told you to do that....there is several different slines that have to line up.....you are a man because I would not have told anyone i had done that.....sorry about the damage.....
