Very basic question...
Old Jul 2, 2007 | 12:36 PM
Gordon0652's Avatar
Default Very basic question...
What is a Transmission brake. I have heard about them in autos. and something about a launch. Can someone tell me what they do?
Thank you.
Old Jul 2, 2007 | 01:33 PM
Gilbert@Ace Racing's Avatar
A transmission Brake basically engages reverse and low gear simultaneously. This allows the engine RPM's to be brought up to the power band at the line without energy being sent into the driveshaft and rear axle... all of the energy is loaded into the geartrain of the transmission and not the rear wheels until the brake is released.
g
Old Jul 2, 2007 | 02:38 PM
Gordon0652's Avatar
Being in two gears esp. reverse and forward wouldnt that hurt your transmission?
Old Jul 2, 2007 | 02:48 PM
smoknta's Avatar
No it locks the tranny still....it build tremendous amounts of heat in the converter and fluid if held on for very long. And it shocks the drivetrain pretty hard when let off. But many drag cars use them to bring the rpms up onto the true stall of the converter.
Old Jul 2, 2007 | 06:32 PM
No it does not damge the trans. Low gear and reverse are the same gear ratio, because of that they are equal and opposing.
g
