Need some bolts for tranny install ASAP
I've got all the parts for my clutch install, however, I need the bolts. I've already ordered the ARP flywheel bolts. What I do need is the pressure plate bolts, and the bolts that bolt the tranny up to the motor. I'm assuming that the bolts for the tranny up to the motor are the same as the bellhousing bolts? Can somebody verify this? However, I'm not sure what the PP bolt specs are. Does anybody know the specs off the top of their head?
Also, a few weeks ago I posted that the tranny did not turn over, nor did it go through all gears. After taking the tranny apart.. I found a piece had come undone, and a friend repaired it for me. This was relatively simple and could be fixed by most! I am very lucky that it was something simple, because I had been told it probably needed a rebuild. I will post a pic of the part in the next few days. I'm pretty sure a tranny shop would have probably tried to rip me off for a rebuild though.
-Josh
-Josh
TTT. Guys, I don't have the original bolts. They = gone. I need these bolts ASAP as this is my daily driver! Thanks!
FYI: This is what I'm installing
Ram 402/980
Mcleod Adjustable Master Cylinder
Slp stock replacement flywheel
Ram 402/980
If a dealer doesn't have them in stock, they can give you the measurements for them (thread & length) so you can pick them up at a hardware place. Hit a dealer in the AM.
Did you ever get the thread/length of the tranny bolts?
I'm looking for ARP bolts for the bellhousing-to-engine bolts, pressure plate bolts, and transfercase-to-bellhousing bolts.
I'm rebuilding the thing and may as well get it done right.
