4l60e Shift Pattern Help....
Old Jul 10, 2007 | 04:23 AM
GunshotZ28's Avatar
Default 4l60e Shift Pattern Help....
Alright, well first of all I have a '95 Camaro Z28 A4. My shift pattern is 2nd, 3rd, and then drive. I have seen plenty of other Z28s , Formulas and Trans Am's with the shift pattern where 1st and 2nd aren't together. I was wondering if there was a way I could have my 1st and 2nd gear seperate instead of together. It would be way more helpful on the high when the local ricers try and pass me. I can never stay in 1st when I want! Any kind of help would be good, thanks.
Old Jul 10, 2007 | 04:57 AM
smoknta's Avatar
Your car must have come with 2.73 gears. You probably have a 115mph speedo also. Your shifter is fine, they just put a plastic piece in to keep you from manually selecting 1st gear. This can be taken out and first gear will be there.
Old Jul 10, 2007 | 02:07 PM
GunshotZ28's Avatar
Yeah stock it had 2.73's but it now has 3.73's. It actually had a 150mph speedometer. So that little plastic piece can be removed? How hard would it be and is there any thread or something about it to where I can look at some pictures unless it isn't that hard I'll just go straight ahead and try it.
