whats all need for repair? codes thrown!
P1860 - TCC PWM Solenoid Circuit Electrical
now will i be fine just replacing the torque converter lockup solenoid? Or is there anything else that would need replaced that could be causing these codes.
one like this-
I believe the lockup solenoid has to be spliced into the harness, correct?
help me!
sorry for all the questions, i just hate doing stuff twice and would rather go into with more knowledge than needed
thanks!
sweet i know exactly what solenoid it is then! Now just a part number and im set, hopefully lol
Added info...Give Chuck a call. I wonder if you are having a converter problem. We do use new solenoids in every unit we build. Not to say that a solenoid can not be bad but I have not seen this happen often.
So now i need to figure out if the fuse some how just randomly let go, or if i have a wirring problem.
Also while I was in the fuse box I found the eng sens fuse to be bad. And to think the car went 11.0s with that fuse bad. As i know that it has been bad since i got the car due to the brake light being on and that fuse also has the brake switch in the system.
