View Poll Results: What is better for all around street/strip performance?
Low Gear Set in Transmission
1
16.67%
New Rear Gear Ratio
5
83.33%
Voters: 6. You may not vote on this poll
Low Gear Set for Street Driven 4L60E
Old Jul 17, 2007 | 06:40 PM
bluebird71's Avatar
Default Low Gear Set for Street Driven 4L60E
I am good friends with one of the chief transmission builders for TCI. He has done all my transmission work on past cars in his own home garage and given me awsome results for extremely low cost. He suggested that I let him rebuild my stock 4L60E in my '01 WS6 with a stout TCI shift kit and a low gear set (bringing the 1st and 2nd gear ratios much lower for better low end drag racing power, but keeping the same 3rd and OD ratios for retained top end and highway driving). He, of course, is going to adjust the stall speed accordingly to give me good pull all around. I want to know from some others who might be using the low gear set on the street what it's advantages and disadvantages are. Also, is this a better all around choice than going with a different rear gear ratio (my stock is 3:23)?
Old Jul 17, 2007 | 06:47 PM
performabuilt's Avatar
LS1Tech Sponsor
This is interesting to me , I was unaware of a lower gear set for the 4L60E can you get a link on there website to it by chance. It would be and odd move though most people complain the low gear in the 4l60e is allready a bit lower than preferred but I still would be interested?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 17, 2007 | 07:12 PM
bluebird71's Avatar
My bad man, you were right. I was assuming that a TH350 had the same stock gear ratio as the 4L60E (they are pretty much the same tranny, except one is electronic). The guy from TCI is actually building a Ford C6 for me with a low gear set and I had asked him to do one for the Trans Am. He said that he would, but I think that it was just casual conversation and he hadn't looked into it yet. I will give him a call and find out more details soon. Thanks for catching that.
Old Jul 17, 2007 | 07:37 PM
john kilgore's Avatar
Default ls
l think your friend that thinks he can change the ratios in the 4L60 is full of lawn sauges.
Old Jul 18, 2007 | 07:04 AM
gator's 99TA's Avatar
never heard of a lower gear set in a 4L60e. if it can be done its custom. its a huge waste of time.
Old Jul 18, 2007 | 01:57 PM
tmaschm's Avatar
Question
I know this same guy and we didn't give him the specific name of the transmission, so he probably just thought there was a set out there for it. Btw next time just say you don't think it can be done cause your stupid post doesn't even make sense.
Old Jul 18, 2007 | 03:05 PM
8a8mfh's Avatar
lawn sauges
= dog ****----get it?
Now......four years ago I seen a set of 700 gears modified to use in a th350. Someone from Hughes showed them to me.
Old Jul 19, 2007 | 10:58 PM
bluebird71's Avatar
Ok, I get it, the 700r4 gear set needs to be left alone, but what are some good mods to strengthen this tranny for better performance (besides stall) I know they have some kind of shift kit from the factory, but is it worth the effort to put a new one in, or is it too early in my LS1 modding to worry about it?
Old Jul 19, 2007 | 11:00 PM
LS1Tech Sponsor
Beast sunshell . Yes a shift kit set up right is worth it. Improved 3-4 set a must
__________________
Call 888-744-6542
Old Nov 15, 2007 | 11:18 PM
jakeshoe's Avatar
LOL,
I hate to dig up an older post but I have to bring this one up.
Do any of you guys know who John Kilgore is?
If he mentions something about transmission gearsets, you MIGHT want to take note.
Old Nov 15, 2007 | 11:19 PM
jakeshoe's Avatar
Nobody is making a "low" gear set for the 700 but there is a set of higher gears made. The prototypes have been done for years and they are going to hit the market pretty soon. 2.66 first ratio.
Old Nov 15, 2007 | 11:21 PM
LS1Tech Sponsor
Interesting we inquired about this with several custom builders , Please let me know when this comes out and who offers it
__________________
Call 888-744-6542
Old Nov 15, 2007 | 11:58 PM
jakeshoe's Avatar
It's a joint venture and there may be some exclusivity agreements. I'm not sure yet. They're in the tooling stage.
Old Nov 16, 2007 | 01:45 AM
ChocoTaco369's Avatar
Tech Resident
You're confusing the TH350 with the 700R4. The 700R4 is the non-electronic 4L60E. The TH350 is a totally different beast altogether when compared to the 4L60E and can be built to take a lot more abuse. It's also only a 3 speed automatic.
