Question about Th400 mount
Old Jul 18, 2007 | 11:47 PM
XpEdItIoUs's Avatar
Default Question about Th400 mount
Should I use a stock m6 mount or a a4 mount?
Old Jul 19, 2007 | 12:22 AM
98turbls1's Avatar
m6 mount and shim to get the right angle... i already have this one covered... i believe the a4 mount won't work with a 4" tailshaft...
Old Jul 19, 2007 | 12:41 AM
XpEdItIoUs's Avatar
btw im using the bmr crossmember for the th400.
Old Jul 19, 2007 | 01:03 AM
98turbls1's Avatar
If you're using the BMR then what are you talking about??? Are you still running stock length torque arm??
Old Jul 19, 2007 | 03:56 AM
Jimmy P's Avatar
Spend the extra $$ and buy a BMR or Yank TH400 crossmember. I was using a M6 crossmember, with a few spacers inbetween to raise it a bit and wasn't happy with the fit. I now have Yank.
Old Jul 19, 2007 | 09:10 AM
XpEdItIoUs's Avatar
I did buy a BMR crossmember, My question is what mount (bushing) do i use for this. Yes i still have stock lenght torque arm, I don't like the shorter kind because either i have to weld a bar across to the subframe connectors or i have to bolt i t on my floor board.
