need tranny/tqc help
Old Jul 20, 2007 | 07:06 PM
MongooseAtHeart's Avatar
Default need tranny/tqc help
whats up im allen im in the OKC area. and i need some help. I have a z28 2002 completely stock except a catback 3 inch magniflow with cut out. and a k & n and a set of 410 gears <- previous owners doing. and this thing is going crazy. its over reving. lagging at half throttle into the 2-3 shift and its just kinda sluggish. its progressively been getting worse. i know the tone is bad on this because some tool had a programmer in it and i cant get it flash back to stock so now its sounds like gravel at wide open because of some bad detination. so i wanted some suggestion if i can ask. i plan on a stall 3500 tci street. and pacesetter long tubes in the next few weeks. any suggestion to help fix some of these tranny issues and such?
thanks
Old Jul 20, 2007 | 07:22 PM
performabuilt's Avatar
LS1Tech Sponsor
What does the fluid look like?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 20, 2007 | 07:32 PM
they are fine check them not to long ago when I changed the oil
Old Jul 20, 2007 | 07:34 PM
they are normal the tranny is a little low but not below the acceptable mark and I just checked them the other day when I changed the oil
Old Jul 20, 2007 | 07:43 PM
LS1Tech Sponsor
I was more interested in the smell and color
__________________
Call 888-744-6542
Old Jul 20, 2007 | 07:49 PM
red and mild burn smell
Old Jul 20, 2007 | 07:53 PM
LS1Tech Sponsor
Well you may very well have some tuning issues but from the sound of it I think you are loosing the 3-4 clutch
__________________
Call 888-744-6542
Old Jul 20, 2007 | 07:58 PM
well ****. so putting the new stall in will probably make it worse? and do you know anywhere near okc or in okc that does dyno tunes on ls1's?
Old Jul 21, 2007 | 12:31 AM
LS1Tech Sponsor
Afraid not sorry
__________________
Call 888-744-6542
