Stripped bolt hole
Old Jul 22, 2007 | 07:25 PM
Captain InsaneO's Avatar
Default Stripped bolt hole
On the drivers side very bottom hole where the bellhousing attatches to the engine I have a bolt hole that is stripped.. it is the one right behind the oil filter. What is the easiest way of fixing it, if there is any? I have running the car with 6 bolts holding my trans to the engine!
On a side note.. I didn't strip it out..
Old Jul 22, 2007 | 07:34 PM
sroach20's Avatar
helicoil or you could just ignore it. some people leave the top bolt of the tranny out and have been fine. just put all but the one stripped one in.
Old Jul 22, 2007 | 07:42 PM
performabuilt's Avatar
LS1Tech Sponsor
It will hold with that one missing but as noted a heli coil or tapping to a larger size are your only options if you want to fix it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
