4L80E swap Front VSS, what pins on PCM?
Originally Posted by JMBLOWNWS6
My 4l80 plugged right into the stock location on the tail shaft.
Different in the cars. I have a 4L80E in my 63 LS1 swap and it's working with out the front VSS. But the 4L80E swap thread says it is used with the Speartech converter and even after HPtuners modifies the file. What's the use of it though? It doesn't look like I "need" it but would like to know what it's use is and if I can benifit from having it hooked up.
