Rev Limitier
Old Jul 31, 2007 | 12:37 PM
Mattsz28's Avatar
Default Rev Limitier
So I was on my way to work this morning and when I found out that the off ramp for my exit was closed after sitting in traffic for about 15 minutes. I proceded to merge back off the exit ramp onto the road. There was plenty of room, but being a chance to got WOT, I did. At the top of first I think the car thwacked the rev Limitier, but the rear end got swirly at the same time . So the questions stands, if the rear end broke loose, could the car thwack the rev limiter, or is my tranmission slipping. I did a series of wot pulls on the highway, none of them from a dig obviously, and detected no slipping or anything but firm crisp shifts. 4l60e 95 lt1 btw.
Old Jul 31, 2007 | 01:12 PM
Mattsz28's Avatar
EDIT : I returned to the area of the off ramp and there are 2 fresh black stripes that match my tire pattern, Still concerned though. What do you guys think?
Old Jul 31, 2007 | 01:41 PM
Gilbert@Ace Racing's Avatar
Your tires breaking loose could indeed cause that if you were close to the rev limiter.
g
Old Jul 31, 2007 | 10:51 PM
dannyz's Avatar
g
I have done this a few times myself. your trans is probbly ok, your spinning the tires is what made you hit the rev limiter.
Old Aug 1, 2007 | 12:56 PM
radz282003's Avatar
+3. It doesn't sound like anything to worry about since you found some marks on the street.
