Stall size with 422/TH400.....4400??
Oh, and a direct port shot. Although I haven't used it yet, I want to be able to cross the finish line.
You do NOT want a higher stall converter is you are going to spray it. Trust me on this one. It is the reason I have a low stall PY3400E - it kills my N/A times, but rocks on the spray.
mti 422 (they just finished it!)
rossler th400 w/ brake
yank 4400
tnt 100 shot just for fun now and then. I don't want a smaller converter since I will mainly be running n/a.
We checked out your home page to get your mods, your stall is correct you just need a STR correction. And as far as the re-stall it is unlimited. You can get in touch with us or take it back to F-Body Central for a STR correction. http://www.ls1-transmission-converter-systems.com/
