st3500 and 315 nittos = smoke
Old Nov 20, 2002 | 08:58 PM
mobius's Avatar
Default st3500 and 315 nittos = smoke
are any of you guys hooking at the track with this combo? i just got back from my first try, crappy track and only ran twice after waiting for 3 hours... first try i heated them up got to the line and nailedd it, lots of smoke and little forward aceeleration 2.4 60ft. next up i stalled it to 1000 rpm and let into it a little easier at about 1/2 throttle they broke loose and a 2.2 60 was the end product. i think my first problem was little track prep. what do you guys think????
Old Nov 20, 2002 | 09:07 PM
Dope's Avatar
Default Re: st3500 and 315 nittos = smoke
Think you're gonna need a lot more tire. I have BFG DRs and just a Yank3000. Can't even stall it up at all or they spin. I launch off idle and still have bad traction problems. Forget about a ST3500! Try ET streets?
Dope
Old Nov 20, 2002 | 09:56 PM
mobius's Avatar
i was thinking 315 drag radials would work but now i think et streets or drags are necessary...
Old Nov 20, 2002 | 10:47 PM
darknight's Avatar
It's the track prep! I have seen people hook on smaller nitto's just cause the track was well prepped. That is a good tire, just try to get your track to do something about the ice capades on the starting line. The 3500 hits hard off the line, but with some practice you'll get it to launch. I have a vig. 3200 and nitto 275/40's and have ran 1.70 60' times on a semi prepped track.
<small>[ November 21, 2002, 09:55 AM: Message edited by: darknight ]</small>
Old Nov 21, 2002 | 06:45 AM
jswhite's Avatar
I had a couple of 1.67 60 fts on 245-50-16 Nittos with mt ST3500. A bad pass was low 1.70's <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Nov 21, 2002 | 10:19 AM
supersp0rt's Avatar
track prep has everything to do with it. i was running 275 nittos last season and could pull consisten 1.8x 60's.
Old Nov 21, 2002 | 11:07 AM
Ragtop 99's Avatar
I've seen a 1.60 on the 245 nittos with a ST 3500 and 3.73s. Track prep has a lot of influence.
Stall it up to 2k and roll hard into the throttle; that should get you into the 1.8s worst case.
Old Nov 21, 2002 | 03:37 PM
Colonel's Avatar
Track prep. I used to pull 1.51s on 275 Nittos.
Old Nov 21, 2002 | 03:44 PM
Colonel's Avatar
Moving to the Drag Racing section... <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<small>[ November 21, 2002, 03:53 PM: Message edited by: Colonel ]</small>
