How many RWHP will a stock 4L60E take?
Old Nov 21, 2002 | 01:43 AM
MUSTANGEATER's Avatar
Default How many RWHP will a stock 4L60E take?
I'm just wondering here? I don't wanna do Heads and Cam and have my tranny die.
Old Nov 21, 2002 | 04:44 PM
JWRENCH's Avatar
Default Re: How many RWHP will a stock 4L60E take?
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> http://www.gm.com/automotive/gmpower.../apps/4l60.htm
Old Nov 21, 2002 | 04:52 PM
LS1LT1's Avatar
It'll take 500rwhp.....for about one pass. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
They are very strong transmissions, you can race them often with stock or near stock power levels all day long without issue and you can even run them hard with some 'real' power and a convertor (MUST use a tranny cooler) behind them on a more limited basis. But putting 375+rwhp through a stock, unbuilt 4L60E on a regular basis will probably cause it to break rather quickly.
Old Nov 21, 2002 | 08:12 PM
fla00z28's Avatar
I have 2000 z with A4 all that I have done to the car is 3.73 gears, freemodes, hpp3, and K&N, 160 stat. I have about 10 1/8 passes and 10-15 1/4 passes, and the tranny is already slipping on me. Not to mention that I don't even have good traction. Goodyear eagle GT2's suck. I am thinking that it might have already had a problem because it never would shift correctly after the gear was put in it. Hope this helps
fla00z28's Avatar
fla00z28's Avatar
Old Nov 21, 2002 | 08:15 PM
fla00z28's Avatar
Old Nov 21, 2002 | 08:16 PM
fla00z28's Avatar
sorry about that guys, comp messed up
Old Nov 21, 2002 | 09:54 PM
Colonel's Avatar
No problem. Just hit "edit/delete", check the "delete post" box and hit "submit." <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
