4l60e rebuild ?s & question about compatability
Old Aug 5, 2007 | 03:43 PM
95GreenZ28's Avatar
Default 4l60e rebuild ?s & question about compatability
I may buy a 4l60e out of a 98 model and I was wondering if the plugs and all are the same as the 2000 model. Also how hard are these trannys to rebuild??
Old Aug 5, 2007 | 03:59 PM
FLT's Avatar
FLT
The trans is a direct bolt in. As far as building it yourself it really depends on your abilities. Check out the sticky at the top of the page to see what you are getting yourself into. "Basement build off"^^^^^^^^^^^^^^
Old Aug 5, 2007 | 04:25 PM
sroach20's Avatar
if youve never done it, good luck. i tried once and will not do that again.
