want to see ratchet shifters installed
#65
Just did th400 swap and went with the pro ratchet shifter..
$8.50 Aluminum
$1.50 Self tapping screws
$200.00 Shifter
So $210, it came with cable, brackets and such, Hammered the stock hole flatter, cut the aluminum with standard cutters. Used step bit to drill hole for cable.
Over all it came out nice, looks stock and hopefully it will take car of the road noise I had with the 6 speed. The release lever is hidden and works well.
$8.50 Aluminum
$200.00 Shifter
#66
man, glad I just came across this thread. Doing th400 FMVB, and was trying to get ideas for a shifter
Anybody have pictures of the black "stealth pro shifter"?
http://www.summitracing.com/parts/BMM-81120/
trying to decide if I want to keep the stock console or go to a 6 speed console for the look.
#73
that looks super nice.
i thought with the handle, it would stick up farther. did you beat the tunnel or mod the shifter?
i was going to do that with a pro bandit, but decided to keep my quicksilver when i went with a glide.
i may end up doing the pro bandit so i can do an electic shift setup.
only problem with it is the price tag.
#75
