want to see ratchet shifters installed
Old 04-30-2013, 02:44 PM
  #101
TJ
TJ's Avatar
oh that one above is clean!
im tired of going through the motions of my quicksilver and im looking into the aerospace shifter or the precision performance shifter. anyone tried to fit these under a 6 spd boot?
Old 05-15-2013, 06:52 PM
  #102
323camaro's Avatar
This is pretty cool stuff... I'm new to all this new shifting stuff. How can I install this, and what do I need
Old 05-16-2013, 10:08 AM
  #103
Outlaw666's Avatar
usually everything you need comes with the shifter...pretty straight forward deal. You can customize the location to suit your needs as well...but that would require a bit of your own personal preference.
Old 05-16-2013, 05:56 PM
  #104
323camaro's Avatar
Do I need to rebuilt the trans and should I just bolt it in.. What does this helps me on
Old 05-16-2013, 07:12 PM
  #105
JustAFooL's Avatar
It helps you in no way if you are still using the stock 60e, it's just more of a looks thing. Any manual body transmission, you almost want a gated shifter just so you don't "miss" that shift. When I had my 60e still, I loved the shifter anyways though. Just more positive shift feeling I guess..
Old 05-16-2013, 08:08 PM
  #106
TJ
TJ's Avatar
i would never have a gated on a 3spd. 2nd to neutral can happen id want a ratchet for sure. on a glide a gated is preferred.
Old 05-16-2013, 08:09 PM
  #107
TJ
TJ's Avatar
i bought the aersopace shifter. im going to see if i can fit it under the console and with the stock boot. i went by the leather shop today and got a price on getting a leather stitched cover for the handle so it wont be all blingy. that or have it powdercoated or anodized black. it may not work out. i had time to order it, no time to tinker with it yet.
Old 05-16-2013, 08:30 PM
  #108
323camaro's Avatar
Is this like having a manual trans
Old 05-16-2013, 09:08 PM
  #109
JustAFooL's Avatar
The shifts feel more positive than the factory shifter, but no, it's nothing like a manual Trans. You can do the same things with the factory shifter, it's just anything looks better than the factory shifter IMO.
I don't know why I said gated, you are correct. I've never even own a gated shifter, Hurst Quarter stick is all I've ever used.
Old 05-17-2013, 09:51 PM
  #110
TJ
TJ's Avatar
quarter stick is gated.
Old 05-18-2013, 10:55 AM
  #111
JustAFooL's Avatar
Another mistake of mine caught by TJ..
Old 05-19-2013, 09:19 PM
  #112
TJ
TJ's Avatar
my bad man. not trying to be a Dbag.
tried to fit the aerospace shifter, no go in a stock 6spd console. the throw is just too long to sit low like i want to. i could probably hack the back off that mounts the shift solenoid, as id never use it, but i dont want to gamble wasting 500 bucks.
tired of the motions of my quicksilver. in the process of trying to fit a pro ratchet. fwiw, the pro ratchet and quicksilver use the same parts, but the lever on the pro ratchet is in the way of the console when mounted in the stock location. going to move it back about an inch and tilt it to the side to gain clearance. i hope i can make it look as good as my quicksilver.
Old 05-24-2013, 02:12 PM
  #113
LS1Tech Sponsor
Beau@SDPC's Avatar
Let's bump this back up. Fixing to do a TH350 swap and gonna try to get a B&M Quicksilver under a factory LT1 A4 console. Would like some more pics and tips.
Old 05-24-2013, 09:33 PM
  #114
TJ
TJ's Avatar
there is ample room to cut down the quicksilver in the front. it fits in a ls1 6spd console with modding, i cant imagine it not fitting in an lt1. got to be more room in there.
Old 08-17-2013, 10:33 PM
  #115
FrankSS's Avatar
Any new console pics?
Old 08-25-2013, 05:41 AM
  #116
Mr Monaro's Avatar
Talking
Any pics on aftermarket shifter on 05 GTO going that wat fittingTH400 BM shifter.
Thanks
Old 08-28-2013, 11:53 AM
  #117
WonBadZ28's Avatar
I used the mounting bracket this guy sells....fits like a glove. just trimmed a little bit but all in all i love it!
https://ls1tech.com/forums/parts-cla...y-console.html
Old 08-29-2013, 07:13 AM
  #118
c0ncEpT's Avatar
Quarter stick
Old 08-29-2013, 08:05 PM
  #119
JustAFooL's Avatar
Thanks for the bump man!
Old 08-31-2013, 05:27 PM
  #120
WonBadZ28's Avatar
Thanks for a great mount!
Quick Reply: want to see ratchet shifters installed
