Help with surging and shifting after converter install
My car is surging and stalling pretty good
when coming to a stop or under very light
throttle to get going especially in reverse.
The throttle plate has been drilled to 15/64.
LS1 edit tuning has also been done by a local
shop. I have a Scanmaster IAC's are 30-40 and
the idle is set to 675. I shimmed the throttle stop. Which helped for a little while, but after
a day or two of driving, problems came back with IAC's hanging around 0-10. Another problem is the 2-3 shift at WOT. It tops out in 2nd and bangs off the limiter until I let up on the gas.
The limiter is at 6800 with a shift point of 6500 (GTP stage 2 heads). Any help appreciated.
- Tom
All is well. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
