servo ???
Old Aug 12, 2007 | 07:45 PM
speedracer1280's Avatar
Default servo ???
I've recently had my mine trans rebuilt with a hughs performance kit..Now I am considering changing servo's... qestion is do the trans am/ camaro come with a corvette servo? they come with a hi po servo but is it worth an up grade to the vette servo or should i go with a billet? I found a website with decent prices...here is a link
http://www.oregonperformancetransmis...de=NTP-K51828C
Old Aug 12, 2007 | 07:54 PM
sroach20's Avatar
already has the vette servo. if you went with a shift kit and a stall, you could do the billet servos. without the stall to smooth things out the servos would feel kind of harsh when shifting.
Old Aug 12, 2007 | 07:59 PM
performabuilt's Avatar
LS1Tech Sponsor
yes you allready have the vette servo.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 12, 2007 | 08:03 PM
cool...thanks saved me a few bucks...I'll opt for the billit servo instead..
Old Aug 12, 2007 | 08:13 PM
LS1Tech Sponsor
Make sure if you use the fairbanks servo that you have a reinforce band performance type other wise use the sonnax
__________________
Call 888-744-6542
Old Aug 12, 2007 | 08:56 PM
Gilbert@Ace Racing's Avatar
While servo's are not very expensive compard to other mods that give a certain bang for the buck do to speak, I am curious to know why you are considering installing an aftermarket billet servo.
If you have a stock powerplant, no need for the upgrade.
If you plan on engine upgrades in the future, then I would suggest that with the correct hydraulic modifications you would not necesarilly need a billet servo.
The billett servos are hard on the band and the drum it interacts with. Now, all that being said, if you are considering going to a higher power output combination... yeah make the change.
Otherwise, it is a waste of money that could be well spent elsewhere... furthermore, the servo could be detrimental to the band if the band was not upgraded.
Hope that helps.
g
Old Aug 12, 2007 | 10:40 PM
LS1Tech Sponsor
Again agreed on the band upgrade do not use a billet servo with a stock band
__________________
Call 888-744-6542
Old Aug 12, 2007 | 11:03 PM
FLT's Avatar
FLT
I think the superior/fairbanks 2nd servo sucks! I got a whole box of them sitting next to the scrap pile! A very abusive piece in my opinion. A vette servo when set up correctly works just fine and if you want a good upgrade get a sonnax second servo. Just my 2 cents. Nighty nite! Vince
