94 TA tranny problems
Old Aug 16, 2007 | 02:29 PM
Reed35's Avatar
Default 94 TA tranny problems
My brother has a 94 TA and the transmission has started acting up. I'm pretty sure it's the 4L60-E, and here are the symptoms.
The car will start fine in park or neutral. And it won't start in gear obviously. The problem is with the car started, (still in park) if you give the car gas, it will go forward. It's almost like it's stuck in drive. IF you shift into Reverse or Neutral and give it gas, it will still go forward.
The car's SES light isn't on either. I pulled apart the console, and everything was fine on the shifter, and everything moved the way it should. Do you guys have any idea what the problem is, and if so, how to fix it?
Old Aug 16, 2007 | 03:17 PM
performabuilt's Avatar
LS1Tech Sponsor
I would first drop the pan and inspect the manual linkage both inside and outside the trans,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 17, 2007 | 11:01 PM
performabuilt2's Avatar
LS1Tech Sponsor
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Aug 17, 2007 | 11:16 PM
FLT's Avatar
FLT
Sounds like the forward clutch has welded itself together. Sounds like your brother is in need of a transmission. Does park work properly? Meaning that it does not roll down an incline for instance. If so then you do not have a linkage issue.
Old Aug 24, 2007 | 09:37 PM
Reed35's Avatar
No, if i put the car in park and start it, it will still jump forward.
Old Aug 24, 2007 | 11:03 PM
LS1Tech Sponsor
i WOULD STILL CHECK THE LINKAGE HOWEVER IT DOES SOUND LIKE VINCE MAY BE RIGHT THE FORWARD CLUTCH IS SEIZED
__________________
Call 888-744-6542
