Which transmission cooler with 3200 stall?
Old May 25, 2003 | 12:00 AM
Okie02's Avatar
Default Which transmission cooler with 3200 stall?
Well im about to order a 3200 stall from tbyrne and i was wanderin which transmission cooler i should get? tbyrne sells B&M coolers. Would this be a good one? thanks!
Old May 25, 2003 | 12:48 AM
highgear's Avatar
Default Re: Which transmission cooler with 3200 stall?
Yes. Get the B&M 24,000 GVW. Works better than 2 other coolers I had.
Old May 25, 2003 | 09:28 AM
Ragtop 99's Avatar
The 19K or 24K Supercooler or similar plate type cooler is fine.
