Can I use a 4wd 4l80e
Old Aug 20, 2007 | 09:31 AM
Krazy98Z28's Avatar
Default Can I use a 4wd 4l80e
I can get my hands on a 4l80E with 30,000 miles on it dirt cheap out of a Silverado, problem is the truck has 4WD.
What has to be done to use this tranny in a F-body.
Marco
Old Aug 20, 2007 | 09:56 AM
sroach20's Avatar
you would need to change the output shaft and tailshaft to a 2wd.
Old Aug 20, 2007 | 10:01 AM
big wally 55's Avatar
You will also have to add a reluctor to the rear carrier in the transmission when it is apart because the 4x4 unit uses a sensor on the transfer case and doesn't have one in the trans for the output sensor !!!!
Old Aug 20, 2007 | 10:24 AM
Krazy98Z28's Avatar
is it too much of a pain in the *** or should i stick with it...although i'm leaning more towards a th-400 right now
Old Aug 20, 2007 | 10:58 AM
john kilgore's Avatar
Default 4x4
there is also a lube hole that is blocked in the 4X trans
Old Aug 20, 2007 | 11:21 PM
Bersaglieri's Avatar
If you dont want it, dont let it go to waste, I'm in NH and for the right price I'll take the 4L80E if you dont.
-Dustin-
