4L60E done for?
Old Aug 20, 2007 | 10:49 PM
Phoenix WS6's Avatar
Default 4L60E done for?
Having a problem with the tranny in my car. Runs fine most of the time but a couple of times now after the car has been driving around for a while it seems like it loses first gear or something. Its horribly sluggish from a stop, have to rev it up to about 2500 just to get it to move. And it doesn't seem to want to shift.
Shut the car off for a while and then start it like an hour later, and its back to normal, don't know what the hell it is. Anybody got any idea?
Old Aug 20, 2007 | 10:52 PM
formula001's Avatar
Sounds like a problem I had. Are you throwing any codes?? I will bet its p0757.
Old Aug 20, 2007 | 10:55 PM
havent taken it in to check codes yet, what was the code you had for?
Old Aug 20, 2007 | 10:56 PM
formula001's Avatar
Is your SES light on. I edited my post up top it was p0757 shift solenoid stuck on
Old Aug 20, 2007 | 11:03 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like your setting limp mode sevral codes can cause this you will need to get it scanned first then post what you find
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 20, 2007 | 11:05 PM
Alright I'll get it scanned and let you guys know what its throwing tomorrow, the SES is on so that might be it. Just got a cam and vig 3200 installed so I automatically assumed the tranny grenaded.
Old Aug 20, 2007 | 11:08 PM
formula001's Avatar
Yeah that was the same thing that happened to me I had a cam installed and I thought I needed to blow more money on a trans but frank helped me out in the wee hours of the night.
Old Aug 21, 2007 | 01:18 PM
turns out its throwing code P0757. Shift solenoid B stuck on.
Old Aug 21, 2007 | 11:43 PM
formula001's Avatar
yuuuup thats what I thought, Did you get the code deleted yet or just had it scanned?
Old Aug 22, 2007 | 01:45 PM
Only had it scanned so far, didnt think they could delete the code completely at autozone, need to get up to my tuner and have it done.
Old Aug 22, 2007 | 06:58 PM
FLT's Avatar
FLT
The code that you are getting might be a false code due to your stall. Have the code cleared and then have the test deleted in your tune. That will probably fix your issue.
