problems?
Old Dec 1, 2002 | 06:08 PM
LS1 Brent's Avatar
Default problems
would there be any sort of problems or side affects if i put a 3200 stall converter on a 1998 z/28 with a ram air intake and slp loudmouth exhaust?
Old Dec 1, 2002 | 07:36 PM
Ragtop 99's Avatar
Default Re: problems
with all converter swaps there 2 common side-effects, that might occur:
1) shift points may need to be adjusted. This takes a HPP3 or Edit or similar device.
2) idle speed may need to be adjusted. This takes a turning the idle set screw on the TB.
With a loudmouth you'll also hear a lot more noise in town because of the extra rpms you'll use before lock-up.
Old Dec 1, 2002 | 07:44 PM
LS1 Brent's Avatar
should i change the shift points to a higher rpm or lower?
