.....help Th 350 Flexplate......
Old Aug 25, 2007 | 08:50 PM
01blackformula's Avatar
Default .....help Th 350 Flexplate......
What type of flex plate do I need to run on a TH350 to work on my 6.0. I have a TCI stock replacement but the holes are off by 1/4''.
Old Aug 25, 2007 | 10:33 PM
jay_lt4's Avatar
if you use a th350 converter with dual bolt pattern the larger th400 pattern will work
Old Aug 28, 2007 | 10:20 AM
Im still having problems with this thing. if anyone has an aftermarket plate what kind are you running??
Old Aug 28, 2007 | 11:58 AM
jay_lt4's Avatar
i just did another 6.0L swap in my brothers malibu this last weekend and we had no issues the stock 6.0L bolted right up to the th350 with a 10" converter,
the stock 6.0L flexplate works perfect,, are you trying to use a flat flex plate or a curved one, this will make a differance on which side of the flex plate you put the spacer on
this tells it all:
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
