need help with trans
Old Aug 26, 2007 | 05:57 PM
njkid's Avatar
Default need help with trans
im putting another trans in my 89 astro van. its the awd. does anyone know wat kind of trans it is. im lost. i got a th350s and th400 around and they dont look alike. any one have any ideas.
Old Aug 26, 2007 | 06:07 PM
performabuilt's Avatar
LS1Tech Sponsor
700r4 4x4 type K on top of the case short output shaft
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 27, 2007 | 11:41 AM
njkid's Avatar
oooo so it a 700r4 with a transfercase?
Old Aug 27, 2007 | 11:54 AM
LS1Tech Sponsor
Yep Lol
__________________
Call 888-744-6542
Old Aug 27, 2007 | 01:55 PM
njkid's Avatar
good to know. thanks alot. a fulltime awd 700r4 right?
Old Aug 27, 2007 | 04:30 PM
LS1Tech Sponsor
Well any 4x4 700r4 will work, the case should have four bolts holing the dust cover on but dont refuse a 6 bolt as you can cut the ears and it will clear also , If you look you will se where GM did the same.The cases in either situation will have a K on the bell housing
__________________
Call 888-744-6542
Old Aug 27, 2007 | 04:55 PM
njkid's Avatar
ooooo i think i see what ur saying. my awd astro van has a 700r4. your saying i can get a 700r4 out of a 4x4 truck and swap the tranfers cases? so swap out the 4x4 case for the awd case. thanks for all of your help. i really appreciate all of your help
Old Aug 29, 2007 | 03:52 PM
njkid's Avatar
swap the tranfers cases? so swap out the 4x4 case for the awd case. . again i really appreciate it
Old Aug 29, 2007 | 06:37 PM
LS1Tech Sponsor
Thats it
__________________
Call 888-744-6542
