4.10 install not a good one -what to do? Help!
It was done with a mechanic which I have a great relationship with. He has done quite a bit of work on my car with much care, but the gear install has not gone well it's a Motive and install Kit from Thunder). After picking it up this morning for the first time and driving it around all day, the whining is definately not normal. It's not just some whining, it's WWII Dive Bomber type shreaking in 6th at cruise, and consistent,loud whining at all speeds and all gears. Have noticed that the whine lets off when I let off the gas. I am not well versed in rear gear knowledge and terms, so I'd like to approach him tomorrow politely armed with a few suggestions. Anyhow, the 80 miles I put on the car could have really done some permanent damage, but I want to keep hope alive and see if this thing can be fixed.
Thanks!
I think 4.10's are hit or mis.
Good luck.
It's kind of discouraging when you open the box and see what the tool consists of. But you really do need it to properly set up the rear end.
His trick is pimpy as hell
