What size of stall do I need????
Old May 29, 2003 | 01:55 PM
BlueSS's Avatar
Default What size of stall do I need????
I'm wanting to put in a TC in my 99 SS, but don't know how big I can go... Can ne of you guys recommend sumthing... I'm gettin the vigilante no doubt I just need to know what size I should get... My mods are 3:73 gears, transgo shift kit, HPPIII, volant cold air induction, 80mm BBK TB, hot wires and plugs, advanced timing sensor from SLP, and all free mods... best 60ft 1.8 best e.t. 13.15 on E.T. streets...
T.A.D
Old May 29, 2003 | 04:51 PM
BlueSS's Avatar
Default Re: What size of stall do I need????
TTT!!!
Old May 29, 2003 | 07:12 PM
02RED Z's Avatar
The only advice I can give is to go one size larger than what you decide on . It will keep you from having to restall in the future .
Old May 29, 2003 | 09:26 PM
Ragtop 99's Avatar
Vig 3600 if you want max performance at the track; Vig 3200 for balance of looseness and performance.
Better get some drag radials too.
Old May 29, 2003 | 10:48 PM
BlueSS's Avatar
Thanx for the reply's guys... I think I might go with the 3200 since i've heard that they usually stall a lil higher than what they are rated at...
Old May 29, 2003 | 11:20 PM
CamaroCain's Avatar
VIG3600
Old May 31, 2003 | 02:59 PM
BlueSS's Avatar
TTT...
Old May 31, 2003 | 05:55 PM
WILWAXU's Avatar
If your looking for a killer ET and can adjust to a looser stall.. the 3600 is the way to go.
The 3200 will offer good performance, and have a little better around town drivability.
